Calc Datei mit Uhrzeit Speichern und Schließen
Jörg
Re: Calc Datei mit Uhrzeit Speichern und Schließen
Beitrag von Jörg »
Sub makeDayCopy()
sMakroName = "makeDayCopy "
sMakroVersion = "2006-08-12 "
sMakroVersion = "2010-08-05"
oComp = StarDesktop.CurrentComponent
' macro run from blank Desktop
If oComp.supportsService(_
	"com.sun.star.frame.StartModule" ) Then
' exit without action
Exit Sub
End If
' macro run from Basic IDE
	"com.sun.star.script.BasicIDE" ) Then
Exit Sub
End If
oDok = ThisComponent
antwort = MsgBox ("Sicherungskopie erstellen?" , 52 , "Sicherung")
if antwort = 7 then
		Exit sub
end if
dim dummy()
   datei="E:\openoffice\Patientendatei.ods"
   dateiurl=converttourl(datei)
   odoc=thisComponent
   odoc.storeasurl(dateiurl,dummy())
If oDok.hasLocation() then
	' check if HELP window is in foreground
	If Instr( oDok.getLocation() , "vnd.sun.star.help:" ) then
		'		msgbox "HELP window in foreground"
	Exit Sub
	End if
	If NOT GlobalScope.BasicLibraries.isLibraryLoaded( "Tools" ) Then
	   GlobalScope.BasicLibraries.loadLibrary( "Tools" )
	End If
	    xFile = "E:\openoffice\Sicherungskopien\" & GetFileNameWithoutExtension(oDok.title,) & format(now(),"YYYY-MM-DD-hh'mm'ss") & ".ods"
    sFileURL=converttourl( xFile )
	Dialoglibraries.Loadlibrary("Standard")
	MyDlg= CreateUnoDialog(Dialoglibraries.Standard.Dialog1)
	MyDlg.setvisible (True)
	myctrl = myDlg.getControl("ProgressBar1")
	myctrl.model.backgroundcolor = RGB (255, 159, 70)
	myctrl.ForegroundColor = RGB (255, 0, 0)
	myctrl.model.ProgressValueMax=100
	for i= 0 to 100
	myDlg.getControl("Label1").Text = "In Arbeit... " & i & " %"
	if i > 75 then
	myctrl.ForegroundColor = RGB (2, 159, 70)
	myDlg.getControl("Label1").Text = "Bin gleich fertig! " & i & " %"
	MyCtrl1=MyDlg.getControl("Label1")
	myctrl1.model.textcolor = RGB (2, 159, 70)
	end if
	myctrl. value = i
	wait 80
	next i
	mydlg.setvisible (false)
if FileExists( sFileURL ) then
		msgbox cDokGefunden & chr(13) &_
			sFileURL & chr(13) & _
			cNoCopyMade ,_
	64 ,sMakroName & sMakroVersion
else
		oDok.StoreToURL( sFileURL , Array() )
end if
Else
	' no filename by now - cannot do a thing
	msgbox cNoLoc & chr(13) &_
		cSaveAndRerun , 64 , sMakroName & sMakroVersion
End If
	oDialog2.endexecute()
antwort = MsgBox ("Sicherungskopie erfolgreich erstellt" & Chr(13) & "Dokument schließen?", 52 , "Sicherung")
if antwort = 7 then
		Exit sub
end if
oDoc = ThisComponent
    checkclose=odoc.ismodified()
    if checkclose=false then
               odoc.close(true)
End sub
End sub
Mußt halt die Pfade entsprechend anpassen. Das Makro speichert mit Dateinamen und Uhrzeit.
Gruß Jörg
Win 10 Pro AOO 4.1.15
Rocko
Beitrag von Rocko »
Zyreon1 hat geschrieben: So, 08.04.2018 11:14leide habe ich noch immer keinen Zugriff auf mein hier Erstelltes Benutzerkonto...
Probiers noch einma!
Zyreon - Dein Passwort
Rocko, Moderator
Zyreon
Beitrag von Zyreon »
Hallo Rocko,
Super Danke kann mein Konto jetzt nutzen :D
Jörg
Beitrag von Jörg »
datei="C:\"Deine Calc-Datei".ods"
Wie heißt Dein Calc-Dokument?
xFile = "C:\Sicherungskopien\" & GetFileNameWithoutExtension(oDok.title,) & format(now(),"YYYY-MM-DD-hh'mm'ss") & ".ods
Existiert bei Dir der Ordner Sicherungskopien?
Diese Makro entweder manuell über Schaltfläche ausführen oder über
Extras->Anpassen-> Dokument wird geschlossen
Gruß Jörg
Zyreon
Hallo Jörg,
Also ich erstelle heute Mittag mal den Datei-Pfad sorry dachte er erstellt den selber.
C:\Vorlage\Vorlage.ods <- Grunddatei
C:\Sicherungskopie\ <- hier erstellt er dann meine Dateien "YYYY-MM-DD-hh'mm'ss"
Kann ich das Makro automatisieren? sobald Vorlage.ods öffnet? (Sorry ich bin nicht so der Code-Crack :O)
Sub makeDayCopy()
Exit Sub
End If
Exit Sub
End If
if antwort = 7 then
		Exit sub
end if
dim dummy()
   datei="C:\Vorlage\Vorlage.ods"
   odoc=thisComponent
	Exit Sub
	End if
	End If
	    xFile = "C:\Sicherungskopien\" & GetFileNameWithoutExtension(oDok.title,) & format(now(),"YYYY-MM-DD-hh'mm'ss") & ".ods"
	for i= 0 to 100
	if i > 75 then
	end if
	myctrl. value = i
	wait 80
	next i
			cNoCopyMade ,_
else
end if
Else
End If
if antwort = 7 then
		Exit sub
end if
               odoc.close(true)
End sub
End sub
Jörg
Beitrag von Jörg »
Eventuell unter EXtras-> Anpassen-> Dokument geöffnet.
Zyreon hat geschrieben: Mo, 09.04.2018 10:27 C:\Sicherungskopie\ <- hier erstellt er dann meine Dateien "YYYY-MM-DD-hh'mm'ss"
Ja, wenn DU einen entsprechenden Ordner in C: hast
Lösch mal noch diese Zeile.
Gruß Jörg
Zyreon
Hallo Jörg,
ich habe die Zeile gelöscht und Verzeichnisse erstellt im Ordner Vorlage liegt meine Vorlage.ods, Makro gestartet.
leider habe ich jetzt wieder einen Fehler "Basic-Syntaxfehler. Erwartet: Sub."
Bild: https://picload.org/view/dawdwcgr/oo-makro.jpg.html
Jörg
Beitrag von Jörg »
hallo,
kann ich jetzt nicht nachvollziehen.
Wie weit läuft das Makro durch?
Stell mal Deinen kompletten Code noch mal rein.
@Moderator
Vielleicht könnte das Thema ins Unterforum Makros verschoben werden?
Gruß Jörg
@Moderator
OK, getan.
Jörg
Beitrag von Jörg »
Danke Stephan !!
Gruß Jörg
Toxitom
Beitrag von Toxitom »
Hey,
der Code ist sehr schlecht geschrieben und sollte dringed überarbeitet ud bereinigt werden. Was direkt auffällt:
... oDoc = ThisComponent
               odoc.close(true)
End sub
End sub
Doppeltes "end sub" am Ende - Syntaxfehler! Führt bei LibreOffice zu der Fehlermeldung "Sub erwartet".
Sub makeDayCopy()
Doppelte Zuweisung eines Wertes zu einer (nicht definierten) Variablen:--> Unsinnig (die erste Zuweisung wird ja direkt wieder überschrieben), schlechter Stil, führt aber nicht zu einem Programmfehler. Verwirrt aber beim Lesen des Codes.
Dazu kommt: Wirres Einrücken und wenig Struktur.
Ich empfehle wirklich, den Code erst mal zu überarbeiten - vielleicht lösen sich dann ja die Probleme "wie von selbst";))
Viele Grüeß
Tom
Jörg
Beitrag von Jörg »
Hallo Toxitom,
hast sicher recht.
Aber bei mir (AOO 4.1.5) läuft er. Auch mit dem 2x End sub.
Hängt möglicherweise mit anderen Codes zusammen.
Würd Euch bitten, den Fragesteller weiter zu unterstützen.
Danke.
Gruß Jörg
Zyreon
Also ich habe openoffice 4.1.5 installiert aber nur mit Calc. Benötige ich dafür zusatz utility´s
ich bin um jede Hilfe dankbar, ich will hier nur keinen Streit :)
Zyreon
Hallo Faol,
Vielen Dank ich habe erst heute gemerkt das bereits die zweite Seite angefangen wurde :P.
Ich teste das Makro heute noch.
die Zeilen ' sind nur Infozeilen und sollte ich bestimmt rauslöschen oder kann ich diese stehen lassen?
MfG Zy
