Wie, mit was ".gml" Öffnen, Verarbeiten?
„das Board“
Beitrag von „das Board“ »
Hi
Mit was kann Ich die Daten verarbeiten?
zb: https://inspire.lfrz.gv.at/001301/ds/2017_ynode.gml
Schein ne XML zu sein:
<?xml version="1.0" ?>
<wfs:FeatureCollection xmlns:net="http://inspire.ec.europa.eu/schemas/net/4.0" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:hfp="http://www.w3.org/2001/XMLSchema-hasFacetAndProperty" xmlns:gml="http://www.opengis.net/gml/3.2" xmlns:tn="http://inspire.ec.europa.eu/schemas/tn/4.0" xmlns:ns1="http://www.w3.org/1999/xhtml" xmlns:tn-ro="http://inspire.ec.europa.eu/schemas/tn-ro/4.0" xmlns:base="http://inspire.ec.europa.eu/schemas/base/3.3" xmlns:gn="http://inspire.ec.europa.eu/schemas/gn/4.0" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gsr="http://www.isotc211.org/2005/gsr" xmlns:gts="http://www.isotc211.org/2005/gts" xmlns:tn-ra="http://inspire.ec.europa.eu/schemas/tn-ra/4.0" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gss="http://www.isotc211.org/2005/gss" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wfs="http://www.opengis.net/wfs/2.0" xsi:schemaLocation="http://inspire.ec.europa.eu/schemas/tn-ra/4.0 http://inspire.ec.europa.eu/schemas/tn-ra/4.0/RailwayTransportNetwork.xsd http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd" numberMatched="1134" numberReturned="1134" timeStamp="2017-10-16T08:46:49.514+02:00">
  <wfs:member>
    <tn-ra:RailwayYardNode gml:id="_db7d11b3-9741-4245-b5e6-aaf2129ab26e">
      <net:beginLifespanVersion>2017-10-15T22:00:00Z</net:beginLifespanVersion>
      <net:inspireId>
        <base:Identifier>
          <base:localId>tn-ra_15532298402</base:localId>
          <base:namespace>AT.0013.TN-RA</base:namespace>
        </base:Identifier>
      </net:inspireId>
      <net:inNetwork xsi:nil="true"/>
      <net:geometry>
        <gml:Point gml:id="_50bdb90a-5aca-49e8-a0ca-de231d4b0ca3" srsDimension="2">
          <gml:pos>497963.72752521484 436847.40217089467</gml:pos>
        </gml:Point>
      </net:geometry>
      <tn:geographicalName>
        <gn:GeographicalName>
          <gn:language>ger</gn:language>
          <gn:nativeness xsi:nil="true"/>
          <gn:nameStatus xsi:nil="true"/>
          <gn:sourceOfName xsi:nil="true"/>
          <gn:pronunciation xsi:nil="true"/>
          <gn:spelling>
            <gn:SpellingOfName>
              <gn:text>BST Kleinreifling</gn:text>
              <gn:script>Latn</gn:script>
            </gn:SpellingOfName>
          </gn:spelling>
        </gn:GeographicalName>
      </tn:geographicalName>
      <tn:validFrom>2016-02-08T23:00:00Z</tn:validFrom>
      <tn:validTo xsi:nil="true"></tn:validTo>
      <tn-ra:formOfNode xlink:href="http://inspire.ec.europa.eu/featureconcept/RailwayYardNode"></tn-ra:formOfNode>
    </tn-ra:RailwayYardNode>
  </wfs:member>
Wie kann ich das alles schön nett ausgeben?
danke!
nikki
Re: Wie, mit was ".gml" Öffnen, Verarbeiten?
Beitrag von nikki »
„das Board“
Ja aber da steht nicht wie Ich die Daten mit Open Office öffnen kann.
Hiker
Beitrag von Hiker »
https://lmgtfy.com/?q=konverter+gml+.ods
Was Du eigentlich brauchst ist eine xslt-Transformation, für Dein Format...
Mfg, Jörn
„das Board“
Seite nicht gefunden wie spannend...
Ich schaue ob Ich die Daten aus QGis exportieren kann. Scheinbar verwendet das Format irgend welche komischen Geo Koordinaten mit den Ich nix anfangen kann. Mal sehen ob QGis die umrechnen kann in der Tabelle.
Ich mag eigentlich "nur" die Bahnhöfe haben und das in einen Format wo Ich die Karte darauf zentrieren kann.
ggrr...
