How to trasfer the content of one field to another field by pressing a button?
Fo example: I have two txtfields Called "Source" and "Destination" . By pressing button "TRANSFER" the data content of "Source" moves in "Destination" (overwriting "Destination "data if present)
When the fields are part of the same SubForm,The following sub works... BUT
sub copy data ( oEv as Object )
dim dbFrm as object
dbFrm = oEv.Source.Model.parent
if not isNull( dbFrm.Destination.BoundField ) then
dbFrm.Destination.BoundField.updateString( _
dbFrm.Source.CurrentValue )
in other words: how do I navigate (or switch) between forms and subforms using oEv.Source or other commands?????
Thank you, and sorry for my english...
problem solved...just use parent.parent to navigate subofrms
