createJNI Fehler - OfficeHome-Pfad falsch?
AlemannenLady
Beitrag von AlemannenLady »
ich bekomme beim Ausführen meiner Java-Datei auf dem Tomcat folgenden Fehler ausgegeben:
ag.ion.bion.officelayer.internal.application.connection.LocalOfficeConnection openConnection
INFO: Opening local OpenOffice.org connection.
ag.ion.bion.officelayer.application.OfficeApplicationException: createJNI
at ag.ion.bion.officelayer.internal.application.LocalOfficeApplication.openConnection(LocalOfficeApplication.java:161)
at ag.ion.bion.officelayer.internal.application.AbstractOfficeApplication.activate(AbstractOfficeApplication.java:118)
at ag.ion.bion.officelayer.internal.application.AbstractOfficeApplication.activate(AbstractOfficeApplication.java:134)
at hurra.Snippet1.main(Snippet1.java:68)
Caused by: java.lang.UnsatisfiedLinkError: createJNI
at com.sun.star.lib.connections.pipe.PipeConnection.createJNI(Native Method)
at com.sun.star.lib.connections.pipe.PipeConnection.<init>(PipeConnection.java:119)
at com.sun.star.lib.connections.pipe.pipeConnector.connect(pipeConnector.java:145)
at com.sun.star.comp.connections.Connector.connect(Connector.java:149)
at ag.ion.bion.officelayer.internal.application.connection.LocalOfficeConnectionGhost.resolve(LocalOfficeConnectionGhost.java:755)
at ag.ion.bion.officelayer.internal.application.connection.LocalOfficeConnectionGhost.connect(LocalOfficeConnectionGhost.java:604)
at ag.ion.bion.officelayer.internal.application.connection.LocalOfficeConnectionGhost.getComponentContext(LocalOfficeConnectionGhost.java:495)
at ag.ion.bion.officelayer.internal.application.connection.LocalOfficeConnection.openConnection(LocalOfficeConnection.java:176)
at ag.ion.bion.officelayer.internal.application.LocalOfficeApplication.openConnection(LocalOfficeApplication.java:157)
Bisher habe ich lokal mit absoluten Pfaden gearbeitet, auf dem Server mit relativen. Außerdem ist der Server eine Linuxmaschine im Gegensatz zu meiner Windowskiste. Woran kann das liegen, dass der diesen Fehler bringt? :roll:
AL
