REM ***** BASIC *****
'Copyright (c) 2006 Winfried Rohr, re-Solutions Software Test Engineering
'mailto: ooo@re-solutions.de Untere Zahlbacher Strasse 18, D-55131 Mainz
'This program is free software; you can redistribute it and/or modify it under
'the terms of the GNU General Public License as published by the Free Software
'Foundation; either version 2 of the License, or (at your option) any later
'version.
'This program is distributed in the hope that it will be useful, but WITHOUT
'ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
'FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
'You should have received a copy of the GNU General Public License along with
'this program; if not, write to the Free Software Foundation, Inc., 59 Temple
'Place, Suite 330, Boston, MA 02111-1307 USA
' make a copy of actual loaded document
' append a date string to filename
' and store in same location
' notice if already exists
' Texte fuer Nachrichten
' Nachricht1
CONST cDokGefunden = "Dokument ist bereits vorhanden:"
'CONST cDokGefunden = "Document found at location"
CONST cNoNewCopy = "Es wurde keine Kopie erzeugt!"
'CONST cNoNewCopy = "No new copy was made!"
'Nachricht2
CONST cNoLoc = "Dokument noch nicht gespeichert (keine URL gefunden)"
'CONST cNoLoc = "Document was not saved yet (could not find an URL)"
CONST cSaveAndRerun = "Erst sichern, dann Makro eventl. erneut abrufen"
'CONST cSaveAndRerun = "Save first, then run this macro again to make a copy"
'Nachricht3
CONST cRunInBase = "Keine Funktion in OOo BASE"
'CONST cRunInBase = "No function in OOo BASE"
CONST cDontWork = "Makro beendet"
' CONST cDontWork = "Macro finished"
'Nachrichten des ErrHandlers
CONST cErrInLine = "Fehler in Zeile: "
'CONST cErrInLine = "Error in line: "
CONST cErrNo = "Fehler-Nr. "
'CONST cErrNo = "Error-No. "
CONST cErrMod = "Fehler in Makro"
'CONST cErrMod = "Error in macro"
Sub makeDayCopy()
sMakroName = "makeDayCopy "
sMakroVersion = "2006-05-20"
' try to catch errors and display a message
On Local Error GoTo ErrHandler
' MAIN
' get active component
oComp = StarDesktop.CurrentComponent
' macro run from blank Desktop
If oComp.supportsService(_
"com.sun.star.frame.StartModule" ) Then
' exit without action
Exit Sub
End If
' macro run from Basic IDE
"com.sun.star.script.BasicIDE" ) Then
Exit Sub
End If
' macro run from Base main window
'Nachricht3
"com.sun.star.sdb.OfficeDatabaseDocument" ) Then
msgbox cRunInBase & chr(13) &_
cDontWork , 64 , sMakroName & sMakroVersion
Exit Sub
End If
oDok = ThisComponent
'XXX warning
'XXX code will fail on next statement, if no document is loaded
' check if file was stored
If oDok.hasLocation() then
' check if HELP window is in foreground
If Instr( oDok.getLocation() , "vnd.sun.star.help:" ) then
' msgbox "HELP window in foreground"
Exit Sub
End if
' yes, make a copy
' compose additional data to create alternative name for file
' here: datestamp in ISO format used (good for sorting)
sFileURL = oDok.getURL() & "_" & cDateToISO( Now() )
' check if such a file exist
if FileExists( sFileURL ) then
' yes there is one
' issue a message to inform user
msgbox cDokGefunden & chr(13) &_
sFileURL & chr(13) & _
cNoCopyMade ,_
64 ,sMakroName & sMakroVersion
else
' check if we have rights to save there under this name
' how ???
' can save with new name
'## note: no checking on length of filename
'## restricted on some platforms
'## untested _ not sure what will happen
oDok.StoreToURL( sFileURL , Array() )
end if
Else
' no filename by now - cannot do a thing
msgbox cNoLoc & chr(13) &_
cSaveAndRerun , 64 , sMakroName & sMakroVersion
End If
Exit sub
ErrHandler:
MsgBox _
cErrInLine & Erl & _
CHR(10) & cErrNo & Err & ": " & Error$ ,, _
cErrMod & sModulName & sModulVersion
End Subich suche verzweifelt
Das einzige makro welches ich gefunden hab ist das hier oben - leider hängt es das datum hinter die dateiendung an (eben als sicherungskopie).
Schön wäre allerdings stattdessen einfach ein dateiname wie 'aktuellesdatum_uhrzeit.ods' oder noch besser 'rechnungsnummer.ods'
Kann mir jemand das obige evtl. umschreiben oder was ähnliches zeigen - ich selber hab von programmierung leider keine ahnung
besten dank
