com.sun.star.awt.UnoControlButtonModel.html#Toggle hat geschrieben: specifies whether the button should toggle on a single operation.
If this property is set to true , a single operation of the button control (pressing space while it is focused, or clicking onto it) toggles it between a pressed and a not pressed state.
The default for this property is false , which means the button behaves like a usual push button.
Since OpenOffice 2.0
Hilft das weiter?
Cheers Winfried
aktuell: LO 5.3.5.2 30m0(Build:2) SUSE rpm, unter Linux openSuSE Leap 42.3 x86_64/KDE5 DateTime2 Einfügen von Datum/Zeit/Zeitstempel (als OOo Extension)
