[Solved] AOO 4.1.7 unter Ubuntu 19.10 - Fehler beim Starten
Benutzer 64387 gelöscht
Beitrag von Benutzer 64387 gelöscht »
Guten Morgen
Ich habe Ubuntu 19.10 auf meinem Rechner (i7-7700, 32 GB RAM, 1 TB SSD) installiert. Leider erhalte ich beim Starten von AOO 4.1.7 folgende Fehlermeldungen:
** (soffice:14715): WARNING **: 08:25:26.834: Unknown type: GailWindow
Application Error
Fatal exception: Signal 6
Stack:
/opt/openoffice4/program/libuno_sal.so.3(+0x37c3a)[0x7efdeb816c3a]
/opt/openoffice4/program/libuno_sal.so.3(+0x37d6c)[0x7efdeb816d6c]
/opt/openoffice4/program/libuno_sal.so.3(+0x37e09)[0x7efdeb816e09]
/lib/x86_64-linux-gnu/libc.so.6(+0x46470)[0x7efdeaed3470]
/lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7efdeaed33eb]
/lib/x86_64-linux-gnu/libc.so.6(abort+0x12b)[0x7efdeaeb2899]
/opt/openoffice4/program/libvcl.so(+0x1557b9)[0x7efde7adc7b9]
/opt/openoffice4/program/libsofficeapp.so(+0x2359b)[0x7efdeb57559b]
/opt/openoffice4/program/libvcl.so(+0x17ff0a)[0x7efde7b06f0a]
/opt/openoffice4/program/libuno_sal.so.3(+0x36a02)[0x7efdeb815a02]
/opt/openoffice4/program/libuno_sal.so.3(+0x37dea)[0x7efdeb816dea]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x7805)[0x7efddf4a5805]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x1cbf4)[0x7efddf4babf4]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x1cf2e)[0x7efddf4baf2e]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x1d079)[0x7efddf4bb079]
/lib/x86_64-linux-gnu/libfontconfig.so.1(FcFontMatch+0x71)[0x7efddf4bbe01]
/opt/openoffice4/program/libvcl.so(+0x137351)[0x7efde7abe351]
/opt/openoffice4/program/libvcl.so(+0x1373e2)[0x7efde7abe3e2]
/opt/openoffice4/program/libvcl.so(_ZN3psp16PrintFontManager20countFontconfigFontsERSt8hash_mapIN3rtl7OStringEiNS2_11OStringHashESt8equal_toIS3_EE+0x35)[0x7efde7abfc17]
/opt/openoffice4/program/libvcl.so(_ZN3psp16PrintFontManager10initializeEv+0x247)[0x7efde7acb21f]
/opt/openoffice4/program/libvcl.so(_ZN3psp16PrintFontManager3getEv+0x49)[0x7efde7acc0e3]
/opt/openoffice4/program/libvclplug_gen.so(_ZN14X11SalGraphics14GetDevFontListEP15ImplDevFontList+0x2c)[0x7efde03db146]
/opt/openoffice4/program/libvcl.so(+0x25a05c)[0x7efde7be105c]
/opt/openoffice4/program/libvcl.so(+0x260bb4)[0x7efde7be7bb4]
/opt/openoffice4/program/libvcl.so(_ZNK12OutputDevice13GetTextHeightEv+0x12)[0x7efde7bea276]
/opt/openoffice4/program/libvcl.so(+0x2637fe)[0x7efde7bea7fe]
/opt/openoffice4/program/libvcl.so(_ZN12OutputDevice8DrawTextERK9RectangleRK6StringtPSt6vectorIS0_SaIS0_EEPS3_PN3vcl11ITextLayoutE+0x195)[0x7efde7bee5f5]
/opt/openoffice4/program/../program/libspl.so(+0x11a1e)[0x7efdccde9a1e]
/opt/openoffice4/program/../program/libspl.so(+0x1129c)[0x7efdccde929c]
/opt/openoffice4/program/../program/libspl.so(+0x128dd)[0x7efdccdea8dd]
/opt/openoffice4/program/libsofficeapp.so(+0x3c1ec)[0x7efdeb58e1ec]
/opt/openoffice4/program/../program/deployment.uno.so(+0x54938)[0x7efdc203a938]
/opt/openoffice4/program/libdeploymentmisc.so(_ZN7dp_misc16syncRepositoriesERKN3com3sun4star3uno9ReferenceINS2_3ucb19XCommandEnvironmentEEE+0x460)[0x7efdea38a170]
/opt/openoffice4/program/libsofficeapp.so(+0x3c290)[0x7efdeb58e290]
/opt/openoffice4/program/libsofficeapp.so(+0x2c8a7)[0x7efdeb57e8a7]
/opt/openoffice4/program/libvcl.so(+0x1807ef)[0x7efde7b077ef]
/opt/openoffice4/program/libvcl.so(_Z6SVMainv+0x1e)[0x7efde7b078ba]
/opt/openoffice4/program/libsofficeapp.so(soffice_main+0x9c)[0x7efdeb5a6ffc]
/opt/openoffice4/program/soffice.bin(main+0xb)[0x400f7b]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7efdeaeb41e3]
/opt/openoffice4/program/soffice.bin(__gxx_personality_v0+0xb9)[0x400eb9]
Mein Vorgehen
  • Java 8 installieren und einrichten
    sudo apt install openjdk-8-jdk
    sudo update-alternatives --config java
    sudo  update-alternatives --config javac
    export JAVA_HOME=$(readlink -f /usr/bin/java | sed "s:bin/java::")
    • Alternative: JRE 8 von https://www.java.com/en/download/linux_manual.jsp herunterladen, auspacken und nach /opt/Oracle_Java/ verschieben:
      sudo update-alternatives --install "/usr/bin/java" "java" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/java" 1
      sudo update-alternatives --install "/usr/bin/javaws" "javaws" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/javaws" 1
      sudo update-alternatives --set "java" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/java"
      sudo update-alternatives --set "javaws" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/javaws"
  • LibreOffice deinstalliert
    sudo apt remove --purge libreoffice*
    sudo apt clean
    sudo apt autoremove
  • OpenOffice 4.1.7 installieren
    sudo apt install -y wget
    wget https://sourceforge.net/projects/openofficeorg.mirror/files/4.1.7/binaries/de/Apache_OpenOffice_4.1.7_Linux_x86-64_install-deb_de.tar.gz
    tar xvf Apache_OpenOffice_4.1.7_Linux_x86-64_install-deb_de.tar.gz
    cd de/DEBS
    sudo dpkg -i *.deb
    cd desktop-integration
    sudo dpkg -i *.deb
Wenn ich dann OpenOffice via Termial starten will, erhalte ich die oben beschriebene Fehlermeldung. Beim googlen habe ich keine verwertbare Lösungen gefunden.
Ich habe es mit beiden Arten von Java probiert: openjdk-8-jdk und jre-8u241
Wer hat eine Idee wie ich das Problem lösen kann? Für Eure geschätzte Hilfe danke ich im Voraus!
Zuletzt geändert von Benutzer 64387 gelöscht am Sa, 29.02.2020 08:49, insgesamt 1-mal geändert.
miesepeter
Re: AOO 4.1.7 unter Ubuntu 19.10 - Fehler beim Starten
Beitrag von miesepeter »
Also in LinuxMint gibt's mit der Installation keine Probleme. Lediglich ist darauf zu achten, dass eine Ersetzung des Mint-Y-themes zum Mint-X-theme vorgenommen wird.
Bei mir fand OpenOffice automatisch OpenJDK (in /usr/lib/jvm/java-11-openjdk-amd64). Ob das dann funktioniert, kann ich nicht sagen, habe aber bisher noch kein Problem festgestellt.
Meiner Ansicht nach ist der Terminalbefehl sudo apt remove --purge libreoffice* möglicherweise problembehaftet.
Du solltest dazu verschiedene Beiträge im Linuxforum dieser Website nachlesen. Außerdem gibt's dort auch den Beitrag AOO parallel zu LO mit voller Desktopintegration installieren. Warum das Rad neu erfinden?
Ciao und viel Erfolg
Guten Tag
Danke für Deine Hilfe. Linux Mint (aktuelle Version) basiert meines Wissens auf Ubuntu 18.04 auf. Unter Ubuntu 18.04.1 habe ich keine Probleme mit dem Starten von AOO 4.1.7. Die Fehlermeldungen erhalte ich nur mit Ubuntu 19.10. --purge entfernt die Konfigurationen, hilfreich, wenn man von vorne beginnen will. Die Deinstallation von LO ist kein Problem. Den Trick mit der paralellen Installation "AOO und LO" führen zum gleichen Ergebnis.
Bin gespannt wer noch andere Lösungsvorschläge hat. Beste Grüsse.
Ich habe die Suite unter Wine installiert und für das was ich sie brauche, läuft es unter Wine perfekt. Somit erachte ich das Problem als gelöst.
Ich danke Euch für Eure Beiträge.
Re: [Solved] AOO 4.1.7 unter Ubuntu 19.10 - Fehler beim Starten
Guten Tag
Ja, dass habe ich auch versucht. Ich bin mit dem Workaround mit Wine voll zufrieden. Für mich hat sich das Problem gelöst.
Beste Grüsse
