Addieren und Subtrahieren innerhalb eines makros funzt ja prima.
Aber wie steht es mit Multiplizieren geht das der net???
Bis jetzt weis ich nur das das hier net funzt!
(13*oSheet.getCellByposition(45,2).value)MFG Dackel
(13*oSheet.getCellByposition(45,2).value)Code: Alles auswählen
Sub Main
oSheet = ThisComponent.Sheets(0)
a = (13*oSheet.getCellByposition(45,2).value)
msgbox a
End SubCode: Alles auswählen
Sub Main
msgbox (13*oSheet.getCellByposition(45,2).value)
if oSheet.getCellByposition(45,2).value = 0 then
r = 255: g = 255: b = 255
else
select case oSheet.getCellByposition(1,26).value
case >= (13*oSheet.getCellByposition(45,2).value)
r = 0: g = 174: b = 0
case >= (10*oSheet.getCellByposition(45,2).value)
r = 138: g = 255: b = 0
case >= (7*oSheet.getCellByposition(45,2).value)
r = 230: g = 255: b = 0
case >= (4*oSheet.getCellByposition(45,2).value)
r = 255: g = 218: b = 0
case >= (oSheet.getCellByposition(45,2).value)
r = 255: g = 138: b = 0
case >= 0
r = 255: g = 0: b = 0
End select
end if
oSheet.getCellByposition(1,26).CellBackcolor = RGB(r,g,b)
else
Msgbox "Case1"
Msgbox "Case2"
Msgbox "Case3"
Msgbox "Case4"
Msgbox "Case5"
case >= 0
Msgbox "Case6"
End select
end if
oSheet.getCellByposition(1,26).CellBackcolor = RGB(r,g,b)Code: Alles auswählen
else
x = oSheet.getCellByposition(45,2).value
case >= 13*x
case >= 10*x
case >= 7*x
case >= 4*x
case >= x
case >= 0
End select
end if
else
case >= (13*x)
case >= 0
End select
end if
else
select case 1*oSheet.getCellByposition(1,26).value
Msgbox "Case1"
Msgbox "Case2"
Msgbox "Case3"
Msgbox "Case4"
Msgbox "Case5"
case >= 0
Msgbox "Case6"
End select
end if
oSheet.getCellByposition(1,26).valueCode: Alles auswählen
13*oSheet.getCellByposition(45,2).valueCode: Alles auswählen
1*oSheet.getCellByposition(1,26).valueCode: Alles auswählen
oSheet.getCellByposition(1,26).value Code: Alles auswählen
13Code: Alles auswählen
